ArcGIS.Core.Data Namespace / VersionBaseType Enumeration
Example Example
    Specifies whether the current geodatabase is connected to a version or a historical version.
    Syntax
    Members
    MemberDescription
    HistoricalVersion Historical version.
    Version Version.
    Example
    Switching between versions
      // Must be called within QueuedTask.Run
      void ChangeVersions(Geodatabase geodatabase, string toVersionName)
        using (VersionManager versionManager = geodatabase.GetVersionManager())
          VersionBaseType versionBaseType = versionManager.GetCurrentVersionBaseType();
          if (versionBaseType == VersionBaseType.Version)
            Version fromVersion = versionManager.GetCurrentVersion();
            Version toVersion = versionManager.GetVersion(toVersionName);
            // Switch between versions
            MapView.Active.Map.ChangeVersion(fromVersion, toVersion);
          if (versionBaseType == VersionBaseType.HistoricalVersion)
            HistoricalVersion fromHistoricalVersion = versionManager.GetCurrentHistoricalVersion();
            HistoricalVersion toHistoricalVersion = versionManager.GetHistoricalVersion(toVersionName);
            // Switch between historical versions
            MapView.Active.Map.ChangeVersion(fromHistoricalVersion, toHistoricalVersion);
          // Switch from HistoricalVersion to Version and vice-versa
          // MapView.Active.Map.ChangeVersion(fromHistoricalVersion, toVersion);
          // MapView.Active.Map.ChangeVersion(fromVersion, toHistoricalVersion);
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Core.Data.VersionBaseType
    Requirements
