ArcGIS.Core.Data Namespace / Index Class / IsAscending Method
    IsAscending Method
    Indicates if the index is based on ascending order. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function IsAscending() As Boolean
    public bool IsAscending()
    Return Value
    true if the index is based on ascending order; otherwise, false.
    Requirements
