ArcGIS.Core.Data Namespace / Index Class / IsUnique Method
    IsUnique Method
    Indicates if the index is unique. If IsUnique is true, the field the Index was created for must not have duplicate values. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function IsUnique() As Boolean
    public bool IsUnique()
    Return Value
    true if the index is unique; otherwise, false.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    Requirements
