QueryDescription object fully describes how a single table in a database or a query layer that is created from one or more database tables (specified by a valid SQL SELECT statement) should be represented as a Table or FeatureClass if the table is spatially enabled.
Public NotInheritable Class QueryDescription Inherits ArcGIS.Core.CoreObjectsBase Implements System.IDisposable
public sealed class QueryDescription : ArcGIS.Core.CoreObjectsBase, System.IDisposable
await QueuedTask.Run(() =>
DatabaseConnectionProperties databaseConnectionProperties = new DatabaseConnectionProperties(EnterpriseDatabaseType.SQLServer)
AuthenticationMode = AuthenticationMode.DBMS,
Instance = "instance",
Database = "database",
User = "user",
Password = "password"
using (Database database = new Database(databaseConnectionProperties))
QueryDescription queryDescription = database.GetQueryDescription("CUSTOMERS");
using (Table table = database.OpenTable(queryDescription))
//use table
User = "user",
QueryDescription queryDescription = database.GetQueryDescription("SELECT OBJECTID, Shape, FACILITYID FROM EmergencyFacility WHERE JURISDICT = 'Municipal'",
"MunicipalEmergencyFacilities");
// Use the table.
System.Object
ArcGIS.Core.Data.QueryDescription
