ArcGIS.Core.Data.NetworkDiagrams Namespace / DiagramElementQueryByElementTypes Class / DiagramElementQueryByElementTypes Constructor
Example
    Initializes a new instance of the DiagramElementQueryByElementTypes class.
    Syntax
    Public Function New()
    public DiagramElementQueryByElementTypes()
    Example
    Change the Layout of a Network Diagram
      // Change the layout of a network diagram by querying for all the diagram elements, editing their shapes,
      static void ChangeDiagramLayout(DiagramManager diagramManager, string diagramName)
        // Retrieve a diagram
        using (NetworkDiagram diagramTest = diagramManager.GetNetworkDiagram(diagramName))
          // Create a DiagramElementQueryByElementTypes query object to get the diagram elements we want to work with
          DiagramElementQueryByElementTypes query = new DiagramElementQueryByElementTypes();
          query.QueryDiagramJunctionElement = true;
          query.QueryDiagramEdgeElement = true;
          query.QueryDiagramContainerElement = true;
          // Retrieve those diagram elements
          DiagramElementQueryResult elements = diagramTest.QueryDiagramElements(query);
          // Create a NetworkDiagramSubset object to edit this set of diagram elements
          NetworkDiagramSubset subset = new NetworkDiagramSubset();
          subset.DiagramJunctionElements = elements.DiagramJunctionElements;
          subset.DiagramEdgeElements = elements.DiagramEdgeElements;
          subset.DiagramContainerElements = elements.DiagramContainerElements;
          // Save the new layout of the diagram elements
          diagramTest.SaveLayout(subset, true);
    Requirements
