ArcGIS.Core.Data.NetworkDiagrams Namespace / DiagramElementQueryByExtent Class / ExtentOfInterest Property
Example
    The extent ArcGIS.Core.Geometry.Envelope used to search for diagram elements; that is, the extent that the resulting queried diagram elements will intersect.
    Syntax
    Public Property ExtentOfInterest As Envelope
    public Envelope ExtentOfInterest {get; set;}
    Example
    Get Diagram Elements
      // Get the diagram elements whose extent intersects the active map extent
      static void GetDiagramElements(MapView mapView, NetworkDiagram networkDiagram)
        // Create a DiagramElementQueryByExtent to retrieve diagram element junctions whose extent
        // intersects the active map extent
        DiagramElementQueryByExtent elementQuery = new DiagramElementQueryByExtent();
        elementQuery.ExtentOfInterest = MapView.Active.Extent;
        elementQuery.AddContents = false;
        elementQuery.QueryDiagramJunctionElement = true;
        elementQuery.QueryDiagramEdgeElement = false;
        elementQuery.QueryDiagramContainerElement = false;
        // Use this DiagramElementQueryByExtent as an argument to the QueryDiagramElements method
        DiagramElementQueryResult result = networkDiagram.QueryDiagramElements(elementQuery);
        // Get the container, junction, edge elements.
        IReadOnlyList<DiagramContainerElement> containerElements = result.DiagramContainerElements;
        // In this case result.DiagramJunctionElements and result.DiagramEdgeElements will be empty
        // because elementQuery.QueryDiagramEdgeElement and elementQuery.QueryDiagramContainerElement are set to 'false'
        IReadOnlyList<DiagramJunctionElement> junctionElements = result.DiagramJunctionElements;
        IReadOnlyList<DiagramEdgeElement> edgeElements = result.DiagramEdgeElements;
    Requirements
