Public ReadOnly Property DiagramJunctionElements As IReadOnlyList(Of DiagramJunctionElement)
public IReadOnlyList<DiagramJunctionElement> DiagramJunctionElements {get;}
// Get the diagram elements whose extent intersects the active map extent
static void GetDiagramElements(MapView mapView, NetworkDiagram networkDiagram)
// Create a DiagramElementQueryByExtent to retrieve diagram element junctions whose extent
// intersects the active map extent
DiagramElementQueryByExtent elementQuery = new DiagramElementQueryByExtent();
elementQuery.ExtentOfInterest = MapView.Active.Extent;
elementQuery.AddContents = false;
elementQuery.QueryDiagramJunctionElement = true;
elementQuery.QueryDiagramEdgeElement = false;
elementQuery.QueryDiagramContainerElement = false;
// Use this DiagramElementQueryByExtent as an argument to the QueryDiagramElements method
DiagramElementQueryResult result = networkDiagram.QueryDiagramElements(elementQuery);
// Get the container, junction, edge elements.
IReadOnlyList<DiagramContainerElement> containerElements = result.DiagramContainerElements;
// In this case result.DiagramJunctionElements and result.DiagramEdgeElements will be empty
// because elementQuery.QueryDiagramEdgeElement and elementQuery.QueryDiagramContainerElement are set to 'false'
IReadOnlyList<DiagramJunctionElement> junctionElements = result.DiagramJunctionElements;
IReadOnlyList<DiagramEdgeElement> edgeElements = result.DiagramEdgeElements;
