await QueuedTask.Run(() =>
try
using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file\\sdefile.sde"))))
using (Table table = geodatabase.OpenDataset<Table>("EmployeeInfo"))
QueryFilter queryFilter = new QueryFilter
WhereClause = "COSTCTRN = 'Information Technology'",
SubFields = "KNOWNAS, OFFICE, LOCATION",
PostfixClause = "ORDER BY OFFICE"
using (RowCursor rowCursor = table.Search(queryFilter, false))
while (rowCursor.MoveNext())
using (Row row = rowCursor.Current)
string location = Convert.ToString(row["LOCATION"]);
string knownAs = Convert.ToString(row["KNOWNAS"]);
catch (GeodatabaseFieldException fieldException)
// One of the fields in the where clause might not exist. There are multiple ways this can be handled:
// Handle error appropriately
using (Table table = geodatabase.OpenDataset<Table>("WaterPipeInfo"))
using (TableDefinition tableDefinition = table.GetDefinition())
bool supportsFullText = geodatabase.GetDatastoreProperties().SupportsFullTextIndex;
if (!supportsFullText)
return;
IReadOnlyList<Index> indexes = tableDefinition.GetIndexes();
IReadOnlyList<Field> fieldsToSearch = indexes.First().GetFields();
FullTextSearchTermExpression searchRepairStatus = new FullTextSearchTermExpression()
SearchFields = fieldsToSearch[0].Name,
SearchTerm = "Repaired",
SearchType = FullTextSearchType.Simple
FullTextSearchTermExpression searchPipeMaterial = new FullTextSearchTermExpression()
SearchFields = fieldsToSearch[1].Name,
SearchTerm = "Copper",
FullTextOrExpression repairedOrCopperEx = new FullTextOrExpression(searchRepairStatus, searchPipeMaterial);
QueryFilter queryfilter = new QueryFilter
FullTextExpression = repairedOrCopperEx,
Offset = 1,
RowCount = 20,
PostfixClause = "Order By Size"
using (RowCursor rowCursor = table.Search(queryfilter, false))
// Use row cursor ...
Task QueryFilterWithPaginationAsync(Table table, List<long> objectIDs) => QueuedTask.Run(() =>
int rowsPerBatch = 100;
int offset = 0;
// Query filter
// Some datastores support pagination only through an SQL postfix clause
QueryFilter queryFilter = new QueryFilter()
ObjectIDs = objectIDs,
PostfixClause = "ORDER BY OBJECTID"
// Fetch rows in a batch from a table
for (int index = offset; index <= objectIDs.Count; index += rowsPerBatch)
// Set number of rows to return from a table
queryFilter.RowCount = rowsPerBatch;
// Set positional offset to skip number of rows from a table
queryFilter.Offset = index;
using (RowCursor cursor = table.Search(queryFilter))
while (cursor.MoveNext())
using (Row row = cursor.Current)
Console.WriteLine(row.GetObjectID());
