ArcGIS.Core.Data.NetworkDiagrams Namespace / DiagramTemplate Class / GetNetworkDiagram Method
The name of the network diagram.
Example
    GetNetworkDiagram Method (DiagramTemplate)
    Gets a NetworkDiagram based on this diagram template with the specified name. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetNetworkDiagram( _
       ByVal name As String _
    ) As NetworkDiagram
    public NetworkDiagram GetNetworkDiagram(
       string name
    Parameters
    name
    Return Value
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred. For example, the name is invalid.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Example
    Get Network Diagrams from a Diagram Template
      // Get all the network diagrams from a template or a diagram by name
      static void GetNetworkDiagramFromDiagramTemplates(UtilityNetwork utilityNetwork)
        using (DiagramManager diagramManager = utilityNetwork.GetDiagramManager())
          // Get the first templates
          DiagramTemplate template = diagramManager.GetDiagramTemplates().FirstOrDefault();
          // Get the network diagrams fromt he template
          IEnumerable<NetworkDiagram> diagrams = template.GetNetworkDiagrams();
          // Get a network diagram by name
          NetworkDiagram diagram = template.GetNetworkDiagram(_diagramName);
    Requirements
