ArcGIS.Core.Data.NetworkDiagrams Namespace / LinearDispatchDiagramLayoutParameters Class / MaximumShift Property
    The maximum distance the junctions with two connections can be spaced from the junctions to which they connect.
    Syntax
    Public Property MaximumShift As Double
    public double MaximumShift {get; set;}
    Remarks
    The default is 2. At the time this distance is reached, junctions are no longer moved during following iterations.
    Requirements
