ArcGIS.Core.Data.NetworkDiagrams Namespace / MainRingDiagramLayoutParameters Class
Members
    Represents the Main Ring diagram layout parameters. This layout algorithm arranges the diagram features in a network diagram around a main ring.
    Syntax
    Public NotInheritable Class MainRingDiagramLayoutParameters
       Inherits DiagramLayoutParameters
    public sealed class MainRingDiagramLayoutParameters : DiagramLayoutParameters
    Remarks
    • This layout algorithm arranges the diagram features around the main ring and hierarchically lays out the subset of diagram features that connect to each diagram junction placed along the main ring.
    • The main ring is the loop formed by the largest number of edges in the network diagram.
    • If the network diagram contains no loops, the Main Ring layout algorithm execution has no effect.
    • This layout algorithm is typically used in the telecommunications industry.
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.Data.NetworkDiagrams.DiagramLayoutParameters
          ArcGIS.Core.Data.NetworkDiagrams.MainRingDiagramLayoutParameters
    Requirements
