ArcGIS.Core.Data.NetworkDiagrams Namespace / NetworkDiagram Class / ApplyLayout Method / ApplyLayout(DiagramLayoutParameters) Method
Predefined layout parameters.
    Apply a predefined layout on all network diagram elements. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Sub ApplyLayout( _
       ByVal layoutParameters As DiagramLayoutParameters _
    public void ApplyLayout(
       DiagramLayoutParameters layoutParameters
    Parameters
    layoutParameters
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    Remarks
    This routine generates its own editing transaction, and therefore cannot be wrapped in a separate transaction. Because the editing performed by this routine cannot be undone, this routine can also not be called within an editing session. All edits in the current edit session must be saved or discarded before calling this routine.
    Requirements
