ArcGIS.Core.Data.NetworkDiagrams Namespace / NetworkDiagram Class / Overwrite Method
An enumerable containing the global IDs of the input geographic features.
Example
    Overwrite Method
    Overwrites this network diagram using a list of geographic features (specified by Global ID). This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub Overwrite( _
       ByVal globalIDs As IEnumerable(Of Guid) _
    public void Overwrite(
       IEnumerable<Guid> globalIDs
    Parameters
    globalIDs
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    Remarks
    This routine generates its own editing transaction, and therefore cannot be wrapped in a separate transaction. Because the editing performed by this routine cannot be undone, this routine can also not be called within an editing session. All edits in the current edit session must be saved or discarded before calling this routine.
    Example
    Editing Network Diagram
      // Various editing operations on a network diagram
      static void EditDiagram(NetworkDiagram diagram, List<Guid> globalIDs)
        // These routines generate their own editing transaction, and therefore cannot be wrapped
        // in a separate transaction. Because the editing performed by these routines cannot
        // be undone, thise routines can also not be called within an editing session. All
        // edits in the current edit session must be saved or discarded before calling these
        // routines.
        // Refresh the diagram - synchronizes it based on the latest network topology
        diagram.Update();
        // Append features to the diagram
        diagram.Append(globalIDs);
        // Overwrite the diagram with a set of features
        diagram.Overwrite(globalIDs);
        NetworkDiagramInfo info = diagram.GetDiagramInfo();
        if (info.CanExtend)
          diagram.Extend(NetworkDiagramExtendType.ExtendByContainment);
          // or extend for only a set of utility network globalIDs
          diagram.Extend(NetworkDiagramExtendType.ExtendByContainment, globalIDs);
        // Delete a diagram
        diagram.Delete();
    Requirements
