ArcGIS.Core.Data.NetworkDiagrams Namespace / ForceDirectedDiagramLayoutParameters.Freedom Enumeration
    Factor that limits the area used to move the diagram junctions during each algorithm iteration.
    Syntax
    Public Enum ForceDirectedDiagramLayoutParameters.Freedom
       Inherits System.Enum
       Implements System.IComparable, System.IConvertible, System.IFormattable, System.ISpanFormattable
    public enum ForceDirectedDiagramLayoutParameters.Freedom : System.Enum, System.IComparable, System.IConvertible, System.IFormattable, System.ISpanFormattable
    Members
    MemberDescription
    High High degree of freedom. The area used to move the diagram junctions will be very large.
    Low Low degree of freedom. The area used to move the diagram junctions will be very limited.
    Medium Medium degree of freedom. The area used to move the diagram junctions will be moderate.
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Core.Data.NetworkDiagrams.ForceDirectedDiagramLayoutParameters.Freedom
    Requirements
