ArcGIS.Core.Geometry Namespace / EnvelopeBuilderEx Class / EnvelopeBuilderEx Constructor / EnvelopeBuilderEx Constructor(MapPoint,MapPoint,SpatialReference)
Lower left corner of the envelope. Cannot be null.
Upper right corner of the envelope. Cannot be null.
(Optional) The spatial reference. The default value is null. The spatial reference of each point is ignored.
    Creates a new instance of the EnvelopeBuilderEx class.
    Syntax
    Public Function New( _
       ByVal minPoint As MapPoint, _
       ByVal maxPoint As MapPoint, _
       Optional ByVal spatialReference As SpatialReference _
    Parameters
    minPoint
    maxPoint
    spatialReference
    Exceptions
    ExceptionDescription
    minPoint or maxPoint is null.
    Remarks
    The spatial references of the input points are ignored. There is no check to see if the spatial references are equal. If either point has coordinates that are outside the domain of the spatial reference, then unexpected results will occur when using the geometry.
    The builder inherits attributes, Z, M and ID-values from the input points. For example, if either minPoint or maxPoint HasZ property is true, then the builder's HasZ property is true.
    The resulting envelope is normalized to ensure its XMin <= XMax, YMin <= YMax. If either of the xy-coordinate values are NaN, then the envelope is set to empty.
    Requirements
