ArcGIS.Core.Geometry Namespace / GeometryBagBuilderEx Class / GeometryBagBuilderEx Constructor / GeometryBagBuilderEx Constructor(IEnumerable<Geometry>,SpatialReference)
The list of geometries to create the GeometryBag.
(Optional) The SpatialReference. The default value is null. The spatial reference of each geometry is ignored.
Example
    Creates a new instance of the GeometryBagBuilderEx class.
    Syntax
    Parameters
    geometries
    spatialReference
    Exceptions
    ExceptionDescription
    geometries is null.
    A geometry in geometries is null. You cannot insert a null geometry into GeometryBag.
    A geometry in geometries is GeometryBag. You cannot insert a GeometryBag into another GeometryBag.
    Index must be equal to -1 or less than or equal to the number of geometries in the builder.
    Remarks
    An Envelope that is inserted into the builder is converted to a Polygon when the GeometryBag is created. As a result, when retrieving an Envelope from a GeometryBag, it will be a Polygon.
    Example
    Construct GeometryBag - from an enumeration of geometries
      // Use a builder convenience method or use a builder constructor.
      MapPoint point = MapPointBuilderEx.CreateMapPoint(10, 20);
      List<Coordinate2D> coords = new List<Coordinate2D>() { new Coordinate2D(50, 60), new Coordinate2D(-120, -70), new Coordinate2D(40, 60) };
      Multipoint multipointNew = MultipointBuilderEx.CreateMultipoint(coords, SpatialReferences.WebMercator);
      Polyline polylineNew = PolylineBuilderEx.CreatePolyline(coords);
      string json = "{\"rings\":[[[0,0],[0,1],[1,1],[1,0],[0,0]],[[3,0],[3,1],[4,1],[4,0],[3,0]]]}";
      Polygon polygonNew = PolygonBuilderEx.FromJson(json);
      var geometries = new List<Geometry>() { point, multipoint, polyline, polygon };
      // Builder convenience methods don't need to run on the MCT.
      var bag = GeometryBagBuilderEx.CreateGeometryBag(geometries, SpatialReferences.WGS84);
      var builder = new GeometryBagBuilderEx(geometries, SpatialReferences.WGS84);
      // do something with the builder
      bag = builder.ToGeometry();
    Requirements
