ArcGIS.Core.Geometry Namespace / GeometryBagBuilderEx Class / GeometryBagBuilderEx Constructor / GeometryBagBuilderEx Constructor(IEnumerable<Geometry>,AttributeFlags,SpatialReference)
The list of geometries to create the GeometryBag.
(Optional) The SpatialReference. The default value is null. The spatial reference of each geometry is ignored.
    Creates a new instance of the GeometryBagBuilderEx class.
    Syntax
    Parameters
    geometries
    attributeFlags
    spatialReference
    Exceptions
    ExceptionDescription
    geometries is null.
    A geometry in geometries is null. You cannot insert a null geometry into a GeometryBag.
    A geometry in geometries is GeometryBag. You cannot insert a GeometryBag into another GeometryBag.
    Remarks
    An Envelope that is inserted into the builder is converted to a Polygon when the GeometryBag is created. As a result, when retrieving an Envelope from a GeometryBag, it will be a Polygon.
    Requirements
