ArcGIS.Core.Geometry Namespace / GeometryBagBuilderEx Class / InsertGeometries Method
0 based index. Specify 0 to insert at the beginning. Specify GeometryCount or -1 to insert at the end.
The geometry to insert.
Example
    Inserts the given list of geometries before the specified index.
    Syntax
    public void InsertGeometries(
       int index,
       IEnumerable<Geometry> geometries
    Public Sub InsertGeometries( _
       ByVal index As Integer, _
       ByVal geometries As IEnumerable(Of Geometry) _
    Parameters
    index
    geometries
    Exceptions
    ExceptionDescription
    geometries is null.
    A geometry in geometries is null. You cannot insert a null geometry into GeometryBag.
    A geometry in geometries is GeometryBag. You cannot insert a GeometryBag into another GeometryBag.
    Index must be equal to -1 or less than or equal to the number of geometries in the builder.
    Remarks
    Specifying -1 for the index is equivalent to AddGeometries.
    An Envelope that is inserted into the builder is converted to a Polygon when the GeometryBag is created. As a result, when retrieving an Envelope from a GeometryBag, it will be a Polygon.
    Example
    Construct GeometryBag - adding or inserting an enumeration of geometries
      MapPoint point = MapPointBuilderEx.CreateMapPoint(10, 20);
      List<Coordinate2D> coords = new List<Coordinate2D>() { new Coordinate2D(50, 60), new Coordinate2D(-120, -70), new Coordinate2D(40, 60) };
      Multipoint multipointNew = MultipointBuilderEx.CreateMultipoint(coords, SpatialReferences.WebMercator);
      Polyline polylineNew = PolylineBuilderEx.CreatePolyline(coords);
      string json = "{\"rings\":[[[0,0],[0,1],[1,1],[1,0],[0,0]],[[3,0],[3,1],[4,1],[4,0],[3,0]]]}";
      Polygon polygonNew = PolygonBuilderEx.FromJson(json);
      var geometries = new List<Geometry>() { point, multipoint, polyline, polygon };
      var builder = new GeometryBagBuilderEx(SpatialReferences.WGS84);
      builder.AddGeometries(geometries);
      GeometryBag geomBag = builder.ToGeometry();
      // geomBag.PartCount == 4    (point, multipoint, polyline, polygon)
      geometries = new List<Geometry>() { point, polyline };
      builder.InsertGeometries(1, geometries);
      // builder.GeometryCount == 6
      // geomBag.PartCount == 6    (point, point, polyline, multipoint, polyline, polygon)
    Requirements
