ArcGIS.Core.Geometry Namespace / GeometryBagBuilderEx Class / InsertGeometry Method
0 based index. Specify 0 to insert at the beginning. Specify GeometryCount or -1 to insert at the end.
The geometry to insert.
Example
    Inserts the given geometry before the specified index.
    Syntax
    public void InsertGeometry(
       int index,
       Geometry geometry
    Public Sub InsertGeometry( _
       ByVal index As Integer, _
       ByVal geometry As Geometry _
    Parameters
    index
    geometry
    Exceptions
    ExceptionDescription
    geometry is null.
    geometry is GeometryBag. You cannot insert a GeometryBag into another GeometryBag.
    Index must be equal to -1 or less than or equal to the number of geometries in the builder.
    Remarks
    Specifying -1 for the index is equivalent to AddGeometry.
    An Envelope that is inserted into the builder is converted to a Polygon when the GeometryBag is created. As a result, when retrieving an Envelope from a GeometryBag, it will be a Polygon.
    Example
    Construct GeometryBag
      MapPoint point = MapPointBuilderEx.CreateMapPoint(1, 2, SpatialReferences.WebMercator);
      List<Coordinate2D> coords2DToUse = new List<Coordinate2D>()
        new Coordinate2D(0, 0),
        new Coordinate2D(0, 1),
        new Coordinate2D(1, 1),
        new Coordinate2D(1, 0)
      Multipoint multipointNew = MultipointBuilderEx.CreateMultipoint(coords2DToUse, SpatialReferences.WGS84);
      Polyline polylineNew = PolylineBuilderEx.CreatePolyline(coords2DToUse, SpatialReferences.WebMercator);
      GeometryBagBuilderEx builder = new GeometryBagBuilderEx(SpatialReferences.WGS84);
      GeometryBag emptyBag = builder.ToGeometry();
      // emptyBag.IsEmpty = true
      builder.AddGeometry(point);
      // builder.GeometryCount = 1
      GeometryBag geometryBag = builder.ToGeometry();
      // geometryBag.PartCount = 1
      // geometryBag.PointCount = 1
      // geometryBag.IsEmpty = false
      IReadOnlyList<ArcGIS.Core.Geometry.Geometry> geometries = geometryBag.Geometries;
      // geometries.Count = 1
      // geometries[0] is MapPoint with a sr of WGS84
      bool isEqual = geometryBag.IsEqual(emptyBag);   // isEqual = false
      builder.InsertGeometry(0, multipoint);
      // geometryBag.PartCount = 2
      // geometries.Count = 2
      // geometries[0] is Multipoint
      // geometries[1] is MapPoint
      builder.AddGeometry(polyline);
      builder.RemoveGeometry(1);
      // geometries[1] is Polyline
    Requirements
