ArcGIS.Core.Geometry Namespace / GeometryBagBuilderEx Class / ToGeometry Method
Example
    ToGeometry Method (GeometryBagBuilderEx)
    Returns a GeometryBag instance representing the current state of the builder.
    Syntax
    public virtual new GeometryBag ToGeometry()
    Public Overridable Shadows Function ToGeometry() As GeometryBag
    Return Value
    Example
    Construct GeometryBag
      MapPoint point = MapPointBuilderEx.CreateMapPoint(1, 2, SpatialReferences.WebMercator);
      List<Coordinate2D> coords2DToUse = new List<Coordinate2D>()
        new Coordinate2D(0, 0),
        new Coordinate2D(0, 1),
        new Coordinate2D(1, 1),
        new Coordinate2D(1, 0)
      Multipoint multipointNew = MultipointBuilderEx.CreateMultipoint(coords2DToUse, SpatialReferences.WGS84);
      Polyline polylineNew = PolylineBuilderEx.CreatePolyline(coords2DToUse, SpatialReferences.WebMercator);
      GeometryBagBuilderEx builder = new GeometryBagBuilderEx(SpatialReferences.WGS84);
      GeometryBag emptyBag = builder.ToGeometry();
      // emptyBag.IsEmpty = true
      builder.AddGeometry(point);
      // builder.GeometryCount = 1
      GeometryBag geometryBag = builder.ToGeometry();
      // geometryBag.PartCount = 1
      // geometryBag.PointCount = 1
      // geometryBag.IsEmpty = false
      IReadOnlyList<ArcGIS.Core.Geometry.Geometry> geometries = geometryBag.Geometries;
      // geometries.Count = 1
      // geometries[0] is MapPoint with a sr of WGS84
      bool isEqual = geometryBag.IsEqual(emptyBag);   // isEqual = false
      builder.InsertGeometry(0, multipoint);
      // geometryBag.PartCount = 2
      // geometries.Count = 2
      // geometries[0] is Multipoint
      // geometries[1] is MapPoint
      builder.AddGeometry(polyline);
      builder.RemoveGeometry(1);
      // geometries[1] is Polyline
    Construct GeometryBag - from an enumeration of geometries
      // Use a builder convenience method or use a builder constructor.
      MapPoint point = MapPointBuilderEx.CreateMapPoint(10, 20);
      List<Coordinate2D> coords = new List<Coordinate2D>() { new Coordinate2D(50, 60), new Coordinate2D(-120, -70), new Coordinate2D(40, 60) };
      Multipoint multipointNew = MultipointBuilderEx.CreateMultipoint(coords, SpatialReferences.WebMercator);
      Polyline polylineNew = PolylineBuilderEx.CreatePolyline(coords);
      string json = "{\"rings\":[[[0,0],[0,1],[1,1],[1,0],[0,0]],[[3,0],[3,1],[4,1],[4,0],[3,0]]]}";
      Polygon polygonNew = PolygonBuilderEx.FromJson(json);
      var geometries = new List<Geometry>() { point, multipoint, polyline, polygon };
      // Builder convenience methods don't need to run on the MCT.
      var bag = GeometryBagBuilderEx.CreateGeometryBag(geometries, SpatialReferences.WGS84);
      var builder = new GeometryBagBuilderEx(geometries, SpatialReferences.WGS84);
      // do something with the builder
      bag = builder.ToGeometry();
    Construct GeometryBag - adding or inserting an enumeration of geometries
      var builder = new GeometryBagBuilderEx(SpatialReferences.WGS84);
      builder.AddGeometries(geometries);
      GeometryBag geomBag = builder.ToGeometry();
      // geomBag.PartCount == 4    (point, multipoint, polyline, polygon)
      geometries = new List<Geometry>() { point, polyline };
      builder.InsertGeometries(1, geometries);
      // builder.GeometryCount == 6
      // geomBag.PartCount == 6    (point, point, polyline, multipoint, polyline, polygon)
    Requirements
