ArcGIS.Core.Geometry Namespace / GeometryEngine Class / QueryPoint Method / QueryPoint(Multipart,SegmentExtensionType,Double,AsRatioOrLength) Method
The multipart on which the returned point lies.
Specifies the extension method.
The distance along the curve or the extended curve at which the returned point lies.
Determines whether the distanceAlongCurve is returned as a ratio of the segment length or as length from the start point.
Example
    Constructs a MapPointat a given distance along the curve or the extended curve.
    Syntax
    Parameters
    multipart
    extensionType
    distanceAlongCurve
    asRatioOrLength
    Return Value
    The point at the given distance along the curve or extended curve.
    Exceptions
    ExceptionDescription
    multipartis null or empty.
    Spatial reference of multipartis an image coordinate system.
    Remarks
    If the distance is less than the length of the curve, then the returned point is the point at that distance along the curve. If the distance is less than zero, or greater than the length of the curve, then the returned point is on the curve specified by the extension method. The distance may be specified as a fixed unit of measure or a ratio of the length of the curve.
    Example
    QueryPoint
      SpatialReference sr = SpatialReferences.WGS84;
      // Horizontal line segment
      Coordinate2D start = new(1, 1);
      Coordinate2D end = new(11, 1);
      LineSegment line = LineBuilderEx.CreateLineSegment(start, end, sr);
      polyline = PolylineBuilderEx.CreatePolyline(line);
      // Don't extend the segment
      MapPoint outPoint = GeometryEngine.Instance.QueryPoint(polyline, SegmentExtensionType.NoExtension, 1.0, AsRatioOrLength.AsLength);
      // outPoint = (2, 1)
      // or the segment
      MapPoint outPoint_seg = GeometryEngine.Instance.QueryPoint(line, SegmentExtensionType.NoExtension, 1.0, AsRatioOrLength.AsLength);
      // outPoint_seg = (2, 1)
      // Extend infinitely in both directions
      outPoint = GeometryEngine.Instance.QueryPoint(polyline, SegmentExtensionType.ExtendTangents, 1.5, AsRatioOrLength.AsRatio);
      // outPoint = (16, 1)
      outPoint_seg = GeometryEngine.Instance.QueryPoint(line, SegmentExtensionType.ExtendTangents, 1.5, AsRatioOrLength.AsRatio);
      // outPoint_seg = (16, 1)
    Requirements
