ArcGIS.Core.Geometry Namespace / GeometryEngine Class / QueryPointAndDistance Method / QueryPointAndDistance(Segment,SegmentExtensionType,MapPoint,AsRatioOrLength,Double,Double,LeftOrRightSide) Method
The curve on which to find the closest point. The curve may be extended.
Describes if, how and where to extend segments.
The input point.
Determines whether the distanceAlongCurve is returned as a ratio of the curve length or as length from the start point.
Describes the distance from the start point of the segment to the input point, either as a ratio or length. If the input point is not on the segment, then the nearest location on the segment from the point is used.
Describes how far the point is from the curve.
Describes if the point is on the left or right side of the curve. The direction of the curve determines its left and right sides. If the point is on the curve, then LeftSide is returned.
Example
    Finds the point on the curve closest to inPoint, then copies that point to outPoint. Also calculates related items.
    Syntax
    Parameters
    segment
    extensionType
    inPoint
    The input point.
    asRatioOrLength
    distanceAlongCurve
    distanceFromCurve
    whichSide
    Return Value
    MapPoint representing the closest point on the curve.
    Exceptions
    ExceptionDescription
    Either segment or inPoint or both are null or empty.
    Spatial reference of segmentis an image coordinate system.
    Example
        // Horizontal line segment
        List<MapPoint> linePts =
          MapPointBuilderEx.CreateMapPoint(1.0, 1.0, SpatialReferences.WGS84),
      MapPointBuilderEx.CreateMapPoint(11.0, 1.0, SpatialReferences.WGS84),
        polyline = PolylineBuilderEx.CreatePolyline(linePts);
        bool isSimple = GeometryEngine.Instance.IsSimpleAsFeature(polyline);
        // Don't extend the segment
        SegmentExtensionType extension = SegmentExtensionType.NoExtension;
        // A point on the line segment
        MapPoint inPoint = MapPointBuilderEx.CreateMapPoint(2, 1, SpatialReferences.WGS84);
        AsRatioOrLength asRatioOrLength = AsRatioOrLength.AsLength;
        MapPoint outPoint = GeometryEngine.Instance.QueryPointAndDistance(polyline, extension, inPoint, asRatioOrLength, out double distanceAlongCurve, out double distanceFromCurve, out LeftOrRightSide whichSide);
        // outPoint = 2, 1
        // distanceAlongCurve = 1
        // distanceFromCurve = 0
        // whichSide = GeometryEngine.Instance.LeftOrRightSide.LeftSide
        // Extend infinitely in both directions
        extension = SegmentExtensionType.ExtendTangents;
        // A point on the left side
        inPoint = MapPointBuilderEx.CreateMapPoint(16, 6, SpatialReferences.WGS84);
        asRatioOrLength = AsRatioOrLength.AsRatio;
        outPoint = GeometryEngine.Instance.QueryPointAndDistance(polyline, extension, inPoint, asRatioOrLength, out distanceAlongCurve, out distanceFromCurve, out whichSide);
        // outPoint = 16, 1
        // distanceAlongCurve = 1.5
        // distanceFromCurve = 5
    Requirements
