ArcGIS.Core.Geometry Namespace / MapPointBuilderEx Class / MapPointBuilderEx Constructor / MapPointBuilderEx Constructor(Double,Double,Double,Double,SpatialReference)
The X-value.
The Y-value.
The Z-value.
The M-value.
(Optional) The SpatialReference. The default value is null.
Example
    Creates a new MapPointBuilderex instance with the given X, Y, Z and M coordinates.
    Syntax
    Public Function New( _
       ByVal x As Double, _
       ByVal y As Double, _
       ByVal z As Double, _
       ByVal m As Double, _
       Optional ByVal spatialReference As SpatialReference _
    public MapPointBuilderEx(
       double x,
       double y,
       double z,
       double m,
       SpatialReference spatialReference
    Parameters
    x
    The X-value.
    y
    The Y-value.
    z
    The Z-value.
    m
    The M-value.
    spatialReference
    Remarks
    The constructed builder's HasZ and HasM properties are set to true.
    Example
    Construct a MapPoint
      // Use a builder convenience method or use a builder constructor.
      // Create a 2D point without a spatial reference
      MapPoint point2D = MapPointBuilderEx.CreateMapPoint(1, 2);
      SpatialReference sr = point2D.SpatialReference; // sr = null
      bool hasZ = point2D.HasZ;   // hasZ = false
      bool hasM = point2D.HasM;   // hasM = false
      bool hasID = point2D.HasID; // hasID = false
      double x = point2D.X;   // x = 1
      double y = point2D.Y;   // y = 2
      double z = point2D.Z;   // z = 0 default value
      double m = point2D.M;   // m is NaN default value
      double id = point2D.ID; // id = 0 default value
      // Or use a builderEx which doesn't need to run on the MCT.
      MapPointBuilderEx builderEx = new MapPointBuilderEx(1, 2);
      // do something with the builder
      builderEx.Y = 3;
      point2D = builderEx.ToGeometry();
      y = point2D.Y;   // y = 3
      // Create a 2D point with a spatial reference
      SpatialReference spatialReference = SpatialReferenceBuilder.CreateSpatialReference(4269);
      point2D = MapPointBuilderEx.CreateMapPoint(1, 2, spatialReference);
      sr = point2D.SpatialReference; // sr != null
      int wkid = sr.Wkid; // wkid = 4269
      // Or use a builder
      builderEx = new MapPointBuilderEx(1, 2, spatialReference);
      // Do something with the builder
      builderEx.SetValues(3, 5);
      x = point2D.X; // x = 3
      y = point2D.Y; // y = 5
      // Change the spatial reference of the builder
      builderEx.SpatialReference = SpatialReferences.WGS84;
      wkid = sr.Wkid; // wkid = 4326
      // Create a 3D point with M
      MapPoint pointZM = MapPointBuilderEx.CreateMapPoint(1, 2, 3, 4);
      sr = pointZM.SpatialReference; // sr = null
      hasZ = pointZM.HasZ;   // hasZ = true
      hasM = pointZM.HasM;   // hasM = true
      hasID = pointZM.HasID; // hasID = false
      x = pointZM.X;   // x = 1
      y = pointZM.Y;   // y = 2
      z = pointZM.Z;   // z = 3
      m = pointZM.M;   // m = 4
      id = pointZM.ID; // id = 0 default value
      // Create a 3D point with M and a spatial reference
      pointZM = MapPointBuilderEx.CreateMapPoint(1, 2, 3, 4, spatialReference);
      sr = pointZM.SpatialReference; // sr != null
      // Create a point from another point in three ways
      MapPoint clone = pointZM.Clone() as MapPoint; // Has the same values including the spatial reference as pointZM
      MapPoint anotherZM = MapPointBuilderEx.CreateMapPoint(pointZM);  // Has the same values including the spatial reference as pointZM
      builderEx = new MapPointBuilderEx(pointZM); // Has the same values including the spatial reference as pointZM
      builderEx.HasM = false;
      builderEx.ID = 7; // Setting the id also sets HasID = true
      MapPoint pointZId = builderEx.ToGeometry();
      sr = pointZId.SpatialReference; // sr != null
      hasZ = pointZId.HasZ;   // hasZ = true
      hasM = pointZId.HasM;   // hasM = false
      hasID = pointZId.HasID; // hasID = true
      x = pointZId.X;   // x = 1
      y = pointZId.Y;   // y = 2
      z = pointZId.Z;   // z = 3
      m = pointZId.M;   // m is NaN, default value
      id = pointZId.ID; // id = 7
      // Create a point with Z, M, and ID-values
      MapPoint pointZMId = MapPointBuilderEx.CreateMapPoint(1, 2, 3, 4, 5, spatialReference);
      sr = pointZMId.SpatialReference; // sr != null
      hasZ = pointZMId.HasZ;   // hasZ = true
      hasM = pointZMId.HasM;   // hasM = true
      hasID = pointZMId.HasID; // hasID = true
      x = pointZMId.X;   // x = 1
      y = pointZMId.Y;   // y = 2
      z = pointZMId.Z;   // z = 3
      m = pointZMId.M;   // m = 4
      id = pointZMId.ID; // id = 5
      // Pick and choose which attributes to include
      MapPoint point = MapPointBuilderEx.CreateMapPoint(1, 2, false, 3, true, 4, true, 5);
      sr = point.SpatialReference; // sr = null
      hasZ = point.HasZ;   // hasZ = false
      hasM = point.HasM;   // hasM = true
      hasID = point.HasID; // hasID = true
      x = point.X;   // x = 1
      y = point.Y;   // y = 2
      z = point.Z;   // z = 0, default value
      m = point.M;   // m = 4
      id = point.ID; // id = 5
      // Or use a builder
      builderEx = new(1, 2, true, 3, false, 4, true, 5);
      builderEx.ID = 7;
      point = builderEx.ToGeometry();
      sr = point.SpatialReference; // sr != null
      hasZ = point.HasZ;   // hasZ = true
      hasM = point.HasM;   // hasM = false
      m = point.M;   // m is NaN, default value
      id = point.ID; // id = 7
    MapPoint Builder Properties
      // MapPointBuilderEx constructors can run on any thread.
      MapPoint point1 = null;
      MapPoint point2 = null;
      SpatialReference spatialReference = SpatialReferenceBuilder.CreateSpatialReference(54004);
      MapPointBuilderEx mapPointBuilder = new MapPointBuilderEx(100, 200, spatialReference);
      SpatialReference sr = mapPointBuilder.SpatialReference; // sr != null
      int wkid = sr.Wkid; // wkid = 54004
      bool hasZ = mapPointBuilder.HasZ;   // hasZ = false
      bool hasM = mapPointBuilder.HasM;   // hasM = false
      bool hasID = mapPointBuilder.HasID; // hasID = false
      bool isEmpty = mapPointBuilder.IsEmpty; // isEmpty = false
      double x = mapPointBuilder.X;   // x = 100
      double y = mapPointBuilder.Y;   // y = 200
      double z = mapPointBuilder.Z;   // z = 0, default value
      double m = mapPointBuilder.M;   // m is NaN, default value
      double id = mapPointBuilder.ID; // id = 0, default value
      mapPointBuilder.Z = 12; // Setting the z-value automatically sets HasZ property to true
      point1 = mapPointBuilder.ToGeometry();
      sr = point1.SpatialReference; // sr != null
      hasZ = point1.HasZ;   // hasZ = true
      hasM = point1.HasM;   // hasM = false
      hasID = point1.HasID; // hasID = false
      x = point1.X;   // x = 100
      y = point1.Y;   // y = 200
      z = point1.Z;   // z = 12
      m = point1.M;   // m is NaN, default value
      id = point1.ID; // id = 0, default value
      // Change some of the builder properties
      mapPointBuilder.SetValues(11, 22);
      mapPointBuilder.HasZ = false;
      mapPointBuilder.HasM = true;
      mapPointBuilder.M = 44;
      // Create another point
      point2 = mapPointBuilder.ToGeometry();
      bool isEqual = point1.IsEqual(point2); // isEqual = false
      // Set the builder to empty
      // Sets X and Y to NaN. Sets other attributes to the default values.
      // Does not change the attribute awareness.
      mapPointBuilder.SetEmpty();
      MapPoint point3 = mapPointBuilder.ToGeometry();
      sr = point3.SpatialReference; // sr != null
      hasZ = point3.HasZ;        // hasZ = false
      hasM = point3.HasM;        // hasM = true
      hasID = point3.HasID;      // hasID = false
      isEmpty = point3.IsEmpty;  // isEmpty = true
      x = point3.X;              // x is NaN
      y = point3.Y;              // y is NaN
      z = point3.Z;              // z = 0, default value
      m = point3.M;              // m is NaN, default value
      id = point3.ID;            // ID = 0, default value
      // Create a builder from a point
      mapPointBuilder = new MapPointBuilderEx(point2); // point1 = (11, 22, 0, 44, 0)
      hasM = mapPointBuilder.HasM;        // hasM = true
      x = mapPointBuilder.X;              // x = 11
      y = mapPointBuilder.Y;              // y = 22
      m = mapPointBuilder.M;              // m = 44
      id = mapPointBuilder.ID;            // ID = 0, default value
      // Setting attribute values automatically sets the corresponding flag to true
      mapPointBuilder.Z = 150;
      mapPointBuilder.ID = 2;
      // Remove the spatial reference
      mapPointBuilder.SpatialReference = null;
      MapPoint point4 = mapPointBuilder.ToGeometry() as MapPoint;
      sr = point3.SpatialReference; // sr = null
      hasZ = point3.HasZ;        // hasZ = true
      hasID = point3.HasID;      // hasID = true
      isEmpty = point3.IsEmpty;  // isEmpty = false
      x = point3.X;              // x = 11
      y = point3.Y;              // y = 22
      z = point3.Z;              // z = 150
      m = point3.M;              // m = 44
      id = point3.ID;            // ID = 2
    Requirements
