ArcGIS.Core.Geometry Namespace / MapPointBuilderEx Class / FromJson Method
JSON string representation of a MapPoint.
Example
    FromJson Method (MapPointBuilderEx)
    Creates a MapPoint from a JSON string representation.
    Syntax
    public static MapPoint FromJson(
       string jsonString
    Public Shared Function FromJson( _
       ByVal jsonString As String _
    ) As MapPoint
    Parameters
    jsonString
    Return Value
    Exceptions
    ExceptionDescription
    The jsonString is empty or null.
    JSON string is invalid or does not represent a MapPoint string.
    Example
    Import and Export Geometries to JSON
      // MapPoint
      string inputString =
        "{\"x\":1,\"y\":2,\"spatialReference\":{\"wkid\":4326,\"latestWkid\":4326}}";
      Geometry geometryFromJson = GeometryEngine.Instance.ImportFromJson(
        JsonImportFlags.JsonImportDefaults, inputString);
      MapPoint importPoint = geometryFromJson as MapPoint;
      // importPoint = 1, 2
      // importPoint.SpatialReference.WKid = 4326
      // use the MapPointBuilderEx convenience method
      MapPoint importPoint2 = MapPointBuilderEx.FromJson(inputString);
      // importPoint2 = 1, 2
      // impointPoint2.SpatialReference.Wkid = 4326
      string outputString = GeometryEngine.Instance.ExportToJson(
        JsonExportFlags.JsonExportDefaults, importPoint);
      // outputString =
      //   "{\"x\":1,\"y\":2,\"spatialReference\":{\"wkid\":4326,\"latestWkid\":4326}}"
      string outputString2 = importPoint.ToJson();
      inputString =
        "{\"spatialReference\":{\"wkid\":4326},\"z\":3,\"m\":4,\"x\":1,\"y\":2}";
      importPoint = GeometryEngine.Instance.ImportFromJson(
        JsonImportFlags.JsonImportDefaults, inputString) as MapPoint;
      // importPoint.HasM = true
      // importPoint.HasZ = true
      // importPoint.X = 1
      // importPoint.Y = 2
      // importPoint.M = 4
      // importPoint.Z = 3
      // export to json - skip spatial reference
                    JsonExportFlags.JsonExportSkipCRS, importPoint);
      // outputString = "{\"x\":1,\"y\":2,\"z\":3,\"m\":4}"
      // export from mappoint, skipping the sr - same as GeometryEngine.Instance.ExportToJson w JsonExportFlags.JsonExportSkipCRS
      outputString2 = importPoint.ToJson(true);
      // Multipoint
      List<Coordinate2D> coords = new List<Coordinate2D>()
      new Coordinate2D(100, 200),
      new Coordinate2D(201, 300),
      new Coordinate2D(301, 400),
      new Coordinate2D(401, 500)
      Multipoint multipointFromCoords = MultipointBuilderEx.CreateMultipoint(
        coords, SpatialReferences.WebMercator);
      inputString =
        "{\"points\":[[100,200],[201,300],[301,400],[401,500]],\"spatialReference\":{\"wkid\":3857}}";
      Multipoint importMultipoint =
               JsonImportFlags.JsonImportDefaults, inputString) as Multipoint;
      // importMultipoint.IsEqual(multipoint) = true
      ReadOnlyPointCollection pointsFromMultipoint = importMultipoint.Points;
      // points.Count = 4
      // points[0] = 100, 200
      // points[1] = 201, 300
      // points[2] = 301, 400
      // points[3] = 401, 500
      // use the MultipointbuilderEx convenience method
      Multipoint importMultipoint2 = MultipointBuilderEx.FromJson(inputString);
      // importMultipoint2.IsEqual(multipoint) = true
      // export to json
                      JsonExportFlags.JsonExportDefaults, multipointFromCoords);
      // outputString = inputString
      // or use the multipoint itself
      outputString2 = multipointFromCoords.ToJson();
      // Polyline
      Polyline polylineFromCoords = PolylineBuilderEx.CreatePolyline(
      // export without the spatial reference
                              JsonExportFlags.JsonExportSkipCRS, polylineFromCoords);
      // import
      geometry = GeometryEngine.Instance.ImportFromJson(
                   JsonImportFlags.JsonImportDefaults, outputString);
      Polyline importPolyline = geometryFromJson as Polyline;
      // importPolyline.SpatialReference = null
      pointsFromMultipoint = importPolyline.Points;
      // points.Count = 4
      // use the polylineBuilderEx convenience method
      Polyline importPolyline2 = PolylineBuilderEx.FromJson(outputString);
      // importPolyline2 = importPolyline
      outputString2 = importPolyline2.ToJson();
      // outputString2 = outputString
      // Polygon
      Polygon polygonFromCoords = PolygonBuilderEx.CreatePolygon(
                                JsonExportFlags.JsonExportSkipCRS, polygonFromCoords);
      // import
      Polygon importPolygon = geometry as Polygon;
      // importPolygon.SpatialReference = null
      pointsFromMultipoint = importPolygon.Points;
      // points.Count = 5
      // polygonBuilderEx convenience method
      Polygon importPolyon2 = PolygonBuilderEx.FromJson(outputString);
      // importPolygon2 = importPolygon
      // export from the polygon
      outputString2 = importPolyon2.ToJson(true);
      // Empty polygon
      polygon = PolygonBuilderEx.CreatePolygon(SpatialReferences.WebMercator);
                                     JsonExportFlags.JsonExportDefaults, polygon);
      importPolygon = GeometryEngine.Instance.ImportFromJson(
                          JsonImportFlags.JsonImportDefaults, outputString) as Polygon;
      // importPolygon.IsEmpty = true
      // importPolygon.SpatialReference.Wkid = 3857
    Requirements
