ArcGIS.Core.Geometry Namespace / ArcOrientation Enumeration
Example Example
    Describes the orientation of an EllipticArcSegment. The orientation is defined as the direction between the 'from' and 'to' points of the arc.
    Syntax
    Members
    MemberDescription
    ArcClockwise The arc proceeds clockwise from its 'from' point to its 'to' point.
    ArcCounterClockwise The arc proceeds counterclockwise from its 'from' point to its 'to' point
    Example
    Construct a Clothoid by Length
      MapPoint startPoint = MapPointBuilderEx.CreateMapPoint(0, 0);
      MapPoint queryPoint = MapPointBuilderEx.CreateMapPoint(3.8, 1);
      double tangentDirection = 0;
      ArcOrientation orientation = ArcOrientation.ArcCounterClockwise;
      double startRadius = double.PositiveInfinity;
      double endRadius = 1;
      ClothoidCreateMethod createMethod = ClothoidCreateMethod.ByLength;
      double curveLength = 10;
      MapPoint pointOnPath;
      double radiusCalculated, tangentDirectionCalculated, lengthCalculated, angleCalculated;
      PolylineBuilderEx.QueryClothoidParameters(queryPoint, startPoint, tangentDirection, startRadius, endRadius, orientation, createMethod, curveLength, out pointOnPath, out radiusCalculated, out tangentDirectionCalculated, out lengthCalculated, out angleCalculated, SpatialReferences.WGS84);
      pointOnPath = MapPointBuilderEx.CreateMapPoint(3.7652656620171379, 1.0332006103128575);
      radiusCalculated = 2.4876382887687227;
      tangentDirectionCalculated = 0.80797056423543978;
      lengthCalculated = 4.0198770235802987;
      angleCalculated = 0.80797056423544011;
      queryPoint = MapPointBuilderEx.CreateMapPoint(1.85, 2.6);
      pointOnPath = MapPointBuilderEx.CreateMapPoint(1.8409964973501549, 2.6115979967308132);
      radiusCalculated = 1;
      tangentDirectionCalculated = -1.2831853071795867;
      lengthCalculated = 10;
      angleCalculated = 5;
      tangentDirection = Math.PI / 4;
      orientation = ArcOrientation.ArcClockwise;
      endRadius = 0.8;
      curveLength = 10;
      Polyline polylineByLength = PolylineBuilderEx.CreatePolyline(startPoint, tangentDirection, startRadius, endRadius, orientation, createMethod, curveLength, CurveDensifyMethod.ByLength, 0.5, SpatialReferences.WGS84);
    Construct a Circle
      // Construct a circle with center at (-1,-1), radius = 2, and oriented clockwise.
      // Use a builderEx convenience method or use a builderEx constructor.
      Coordinate2D centerPtCoord = new Coordinate2D(-1, -1);
      // Builder convenience methods don't need to run on the MCT.
      EllipticArcSegment circle = EllipticArcBuilderEx.CreateCircle(centerPtCoord, 2, ArcOrientation.ArcClockwise);
      // circle.IsCircular = true
      // circle.IsCounterClockwise = false
      // circle.IsMinor = false
      double startAngle, rotationAngle, centralAngle, semiMajor, semiMinor;
      Coordinate2D actualCenterPt;
      circle.QueryCoords(out actualCenterPt, out startAngle, out centralAngle, out rotationAngle, out semiMajor, out semiMinor);
      // semiMajor = 2.0
      // semiMinor = 2.0
      // startAngle = PI/2
      // centralAngle = -2*PI
      // rotationAngle = 0
      // endAngle = PI/2
      // This EllipticArcBuilderEx constructor doesn't need to run on the MCT.
      EllipticArcBuilderEx builder = new EllipticArcBuilderEx(centerPtCoord, 2, ArcOrientation.ArcClockwise);
      EllipticArcSegment otherCircle = builder.ToSegment();
    Create Circle Graphic
      await QueuedTask.Run(() =>
      //Build geometry
      Coordinate2D center = new Coordinate2D(2, 4);
      EllipticArcSegment circle_seg = EllipticArcBuilderEx.CreateCircle(
        new Coordinate2D(2, 4), 0.5, ArcOrientation.ArcClockwise, null);
      var circle_poly = PolygonBuilderEx.CreatePolygon(PolylineBuilderEx.CreatePolyline(circle_seg));
      //PolylineBuilderEx.CreatePolyline(cir, AttributeFlags.AllAttributes));
      //Set symbology, create and add element to layout
      CIMStroke outline = SymbolFactory.Instance.ConstructStroke(
        ColorFactory.Instance.BlackRGB, 2.0, SimpleLineStyle.Dash);
      CIMPolygonSymbol circleSym = SymbolFactory.Instance.ConstructPolygonSymbol(
        ColorFactory.Instance.RedRGB, SimpleFillStyle.Solid, outline);
      SymbolFactory.Instance.ConstructPolygonSymbol(null,
        SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.RedRGB, 2));
      var circleGraphic = GraphicFactory.Instance.CreateSimpleGraphic(circle_poly, circleSym);
      //Make an element to add to GraphicsLayer or Layout
      //var elemInfo = new ElementInfo() { Anchor = Anchor.CenterPoint };
      //GraphicElement cirElm = ElementFactory.Instance.CreateGraphicElement(
        //  layout, circleGraphic, "New Circle", true, elemInfo);
    Create Ellipse Text Element
      //Build geometry
      Coordinate2D center = new Coordinate2D(4.5, 2.75);
      var eabElp = new EllipticArcBuilderEx(center, 0, 1, 0.45, ArcOrientation.ArcClockwise);
      var ellipse = eabElp.ToSegment();
      var poly = PolygonBuilderEx.CreatePolygon(
        PolylineBuilderEx.CreatePolyline(ellipse, AttributeFlags.AllAttributes));
      CIMTextSymbol sym = SymbolFactory.Instance.ConstructTextSymbol(
                            ColorFactory.Instance.BlueRGB, 10, "Arial", "Regular");
      string text = "Ellipse, ellipse, ellipse";
      GraphicElement ge = ElementFactory.Instance.CreateTextGraphicElement(
        layout, TextType.PolygonParagraph, poly, sym, text, "New Ellipse Text", false);
    Create Predefined Shape Graphic Element 3
      //Build geometry
      Coordinate2D center = new Coordinate2D(2, 2.75);
                            ColorFactory.Instance.GreenRGB, 2.0, SimpleLineStyle.Dot);
      CIMPolygonSymbol ellipseSym = SymbolFactory.Instance.ConstructPolygonSymbol(
                       ColorFactory.Instance.GreyRGB, SimpleFillStyle.Vertical, outline);
      var ge = ElementFactory.Instance.CreatePredefinedShapeGraphicElement(
        layout, PredefinedShape.Ellipse, poly.Extent.Center, 0, 0, ellipseSym,
        "New Ellipse2", false, new ElementInfo() { Anchor = Anchor.TopRightCorner });
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Core.Geometry.ArcOrientation
    Requirements
