Return Value
The parent Table of this row.
| Exception | Description |
| System.NotSupportedException | This instance of Row/Feature does not have a parent Table/FeatureClass (e.g., if it is obtained via a QueryDef). |
| ArcGIS.Core.Data.Exceptions.GeodatabaseException | A geodatabase-related exception has occurred. |
await QueuedTask.Run(() =>
using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file"))))
QueryDef adaCompilantParksQueryDef = new QueryDef
Tables = "Park",
WhereClause = "ADACOMPLY = 'Yes'",
using (RowCursor rowCursor = geodatabase.Evaluate(adaCompilantParksQueryDef, false))
while (rowCursor.MoveNext())
using (Row row = rowCursor.Current)
Feature feature = row as Feature;
Geometry shape = feature.GetShape();
String type = Convert.ToString(row["ADACOMPLY"]); // will be "Yes" for each row.
try
Table table = row.GetTable(); // Will always throw exception.
catch (NotSupportedException exception)
// Handle not supported exception.
Task<string> GetDomainStringFromFieldAsync(Row row, Field field) => QueuedTask.Run(() =>
// Get the table and table definition from the Row
using (Table table = row.GetTable())
using (TableDefinition tableDefinition = table.GetDefinition())
// Get name of subtype field
string subtypeFieldName = tableDefinition.GetSubtypeField();
// Get subtype, if any
Subtype subtype = null;
if (subtypeFieldName.Length != 0)
// Get value of subtype field for this row
object varSubtypeCode = row[subtypeFieldName];
long subtypeCode = (long)varSubtypeCode;
// Get subtype for this row
subtype = tableDefinition.GetSubtypes().First(x => x.GetCode() == subtypeCode);
// Get the coded value domain for this field
CodedValueDomain domain = field.GetDomain(subtype) as CodedValueDomain;
// Return the text string for this field
if (domain != null)
return domain.GetName(row[field.Name]);
return row[field.Name].ToString();
