ArcGIS.Desktop.Editing Namespace / RubbersheetMethod Class / RubbersheetType Property
Example
    Gets or sets the rubbersheet method to use.
    Syntax
    public RubbersheetMethodType RubbersheetType {get; set;}
    Public Property RubbersheetType As RubbersheetMethodType
    Example
    Edit Operation Rubbersheet Features
    // Performs a rubber-sheet transformation on the features of a specified layer using the provided link lines, anchor points, and limited adjustment areas.
    await QueuedTask.Run(() =>
      //Perform rubber-sheet by geometries
      var rubbersheetMethod = new RubbersheetByGeometries()
        RubbersheetType = RubbersheetMethodType.Linear, //The RubbersheetType can be Linear of NearestNeighbor
        LinkLines = linkLines, //IEnumerable list of link lines (polylines)
        AnchorPoints = anchorPoints, //IEnumerable list of anchor points (map points)
        LimitedAdjustmentAreas = limitedAdjustmentAreas //IEnumerable list of limited adjustment areas (polygons)
      var rubbersheetOp = new EditOperation();
      //Performs linear rubber-sheet transformation on the features belonging to "layer" that fall within the limited adjustment areas
      rubbersheetOp.Rubbersheet(layer, rubbersheetMethod);
      //Execute the operation
      if (!rubbersheetOp.IsEmpty)
        var result = rubbersheetOp.Execute(); //Execute and ExecuteAsync will return true if the operation was successful and false if not
      //Alternatively, you can also perform rubber-sheet by layer
      var rubbersheetMethod2 = new RubbersheetByLayers()
        RubbersheetType = RubbersheetMethodType.NearestNeighbor, //The RubbersheetType can be Linear of NearestNeighbor
        LinkLayer = linkLayer,
        AnchorPointLayer = anchorPointsLayer,
        LimitedAdjustmentAreaLayer = limitedAdjustmentAreaLayer
      //Performs nearest neighbor rubber-sheet transformation on the features belonging to "layer" that fall within the limited adjustment areas
      rubbersheetOp.Rubbersheet(layer, rubbersheetMethod2);
    Requirements
