ArcGIS.Desktop.Editing.Controls Namespace / TableControl Class / GetRowIndex Method
The object id of the row.
Only search the active pages of the table for the object id.
    GetRowIndex Method (TableControl)
    Gets the index of a row in the current ViewMode of the table. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetRowIndex( _
       ByVal objectId As Long, _
       ByVal activePageSearch As Boolean _
    ) As Integer
    public int GetRowIndex(
       long objectId,
       bool activePageSearch
    Parameters
    objectId
    activePageSearch
    Return Value
    The index of the row or -1 if the object id is not found.
    Exceptions
    ExceptionDescription
    Requirements
