ArcGIS.Desktop.Mapping Namespace / MappingExtensions Class / BuildMapTopologyGraph Method / BuildMapTopologyGraph<T>(MapView,Action<TopologyGraph>) Method
The map view.
The client action that receives a ArcGIS.Core.Data.Topology.TopologyGraph as input for analysis.
Example
    Build the Map Topology Graph.
    Syntax
    Public Overloads Shared Sub BuildMapTopologyGraph(Of T)( _
       ByVal mapView As MapView, _
       ByVal action As Action(Of TopologyGraph) _
    public static void BuildMapTopologyGraph<T>(
       MapView mapView,
       Action<TopologyGraph> action
    Parameters
    mapView
    The map view.
    action
    Type Parameters
    T
    Exceptions
    ExceptionDescription
    Example
    Build Map Topology
    // Builds the map topology graph for the active map view and displays the number of topology nodes and edges.
    await QueuedTask.Run(() =>
      //Build the map topology graph
      MapView.Active.BuildMapTopologyGraph<TopologyDefinition>(topologyGraph =>
        //Getting the nodes and edges present in the graph
        var topologyGraphNodes = topologyGraph.GetNodes();
        var topologyGraphEdges = topologyGraph.GetEdges();
        foreach (var node in topologyGraphNodes)
          // do something with the node
        foreach (var edge in topologyGraphEdges)
          // do something with the edge
        MessageBox.Show($"Number of topo graph nodes are:  {topologyGraphNodes.Count}.\n Number of topo graph edges are {topologyGraphEdges.Count}.", "Map Topology Info");
    Requirements
