ArcGIS.Desktop.Layouts Namespace / ArrowInfo Class / LineWidthPoints Property
Example
    The width of the arrow line in points
    Syntax
    Public Property LineWidthPoints As Double
    public double LineWidthPoints {get; set;}
    Example
    Create Arrow Graphic
      //Note: Must be on QueuedTask.Run
      //Build geometry
      List<Coordinate2D> plCoords = new List<Coordinate2D>();
      plCoords.Add(new Coordinate2D(1, 8.5));
      plCoords.Add(new Coordinate2D(1.66, 9));
      plCoords.Add(new Coordinate2D(2.33, 8.1));
      plCoords.Add(new Coordinate2D(3, 8.5));
      Polyline linePl = PolylineBuilderEx.CreatePolyline(plCoords);
      //Set up the arrow info
      var arrowInfo = new ArrowInfo()
        ArrowHeadKey = ArrowInfo.DefaultArrowHeadKeys[1],
        ArrowOnBothEnds = true,
        ArrowSizePoints = 30,
        LineWidthPoints = 15
      var graphic = GraphicFactory.Instance.CreateArrowGraphic(linePl, arrowInfo);
      //Make an element to add to GraphicsLayer or Layout
      //var ge = ElementFactory.Instance.CreateGraphicElement(
      //  layout, graphic, "Arrow Line", false);
    Create Line Arrow Element
      //Note: Must be on QueuedTask.Run(() => { ...
      //Build geometry
        ArrowHeadKey = ArrowInfo.DefaultArrowHeadKeys[8],
        ArrowSizePoints = 24,
        LineWidthPoints = 12
      //Create and add element to layout
      GraphicElement lineElm = ElementFactory.Instance.CreateArrowGraphicElement(
        layout, linePl, arrowInfo, "Arrow Line", true,
                                  new ElementInfo() { Rotation = 15.0 });
      //lineElm.SetName("New Line");
    Requirements
