ArcGIS.Desktop.Layouts Namespace / Element Class / SetTOCPositionRelative Method / SetTOCPositionRelative(IElement,Boolean) Method
An existing IElement in the layout TOC.
Set to true to place the target above the reference element
    Sets the position of an element either above or below a reference element. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void SetTOCPositionRelative(
       IElement targetElement,
       bool isAbove
    Public Overloads Sub SetTOCPositionRelative( _
       ByVal targetElement As IElement, _
       ByVal isAbove As Boolean _
    Parameters
    targetElement
    isAbove
    Exceptions
    ExceptionDescription
    This method must be called within the lambda passed to QueuedTask.Run.
    Remarks
    The reference element can either be at the root level of the layout TOC or an element in a group element. Elements can be easily moved into or out of groups.
    Requirements
