var project = Project.Current;
await QueuedTask.Run(() =>
//Build geometry
Coordinate2D coord2D = new Coordinate2D(2.0, 10.0);
//Reference a point symbol in a style
StyleProjectItem stylePrjItm = project.GetItems<StyleProjectItem>()
.FirstOrDefault(item => item.Name == "ArcGIS 2D");
SymbolStyleItem symStyleItm = stylePrjItm.SearchSymbols(
StyleItemType.PointSymbol, "City Hall")[0];
CIMPointSymbol pointSym = symStyleItm.Symbol as CIMPointSymbol;
pointSym.SetSize(50);
var elemInfo = new ElementInfo()
CustomProperties = new List<CIMStringMap>() {
new CIMStringMap() { Key = "Key1", Value = "Value1"},
new CIMStringMap() { Key = "Key2", Value = "Value2"}
Anchor = Anchor.TopRightCorner,
Rotation = 45.0
var graphic = GraphicFactory.Instance.CreateSimpleGraphic(
coord2D.ToMapPoint(), pointSym);
ElementFactory.Instance.CreateGraphicElement(
layout, graphic, "New Point", true, elemInfo);
//Build geometry
Coordinate2D ll = new Coordinate2D(1.0, 4.75);
Coordinate2D ur = new Coordinate2D(3.0, 5.75);
Envelope env = EnvelopeBuilderEx.CreateEnvelope(ll, ur);
//Set symbology, create and add element to layout
CIMStroke outline = SymbolFactory.Instance.ConstructStroke(
ColorFactory.Instance.BlackRGB, 5.0, SimpleLineStyle.Solid);
CIMPolygonSymbol polySym = SymbolFactory.Instance.ConstructPolygonSymbol(
ColorFactory.Instance.GreenRGB, SimpleFillStyle.DiagonalCross, outline);
var ge = GraphicFactory.Instance.CreateSimpleGraphic(env, polySym);
Anchor = Anchor.CenterPoint,
Rotation = 45.0,
CornerRounding = 5.0
layout, env, polySym, "New Rectangle", false, elemInfo);
//Create a simple point text element and assign basic symbology and text settings.
//Build 2D point geometry
Coordinate2D coord2D = new Coordinate2D(3.5, 10);
CIMTextSymbol sym = SymbolFactory.Instance.ConstructTextSymbol(
ColorFactory.Instance.RedRGB, 32, "Arial", "Regular");
string textString = "Point text";
//use ElementInfo to set placement properties during create
Rotation = 45
var ptTxtElm = ElementFactory.Instance.CreateTextGraphicElement(
layout, TextType.PointText, coord2D.ToMapPoint(), sym, textString,
"New Point Text", true, elemInfo);
//Change additional text properties
ptTxtElm.SetX(4.5);
ptTxtElm.SetY(9.5);
//create a picture element
var imgPath = @"https://www.esri.com/content/dam/esrisites/en-us/home/" +
"homepage-tile-podcast-business-resilience-climate-change.jpg";
//Build a geometry to place the picture
Coordinate2D ll = new Coordinate2D(3.5, 1);
Coordinate2D ur = new Coordinate2D(6, 5);
//create a picture element on the page
var gElement = PresentationElementFactory.Instance.CreatePictureGraphicElement(page, env, imgPath);
//create a text element
//Set symbology, create and add element to a presentation page
ColorFactory.Instance.RedRGB, 15, "Arial", "Regular");
Rotation = 45
string textString = "My text";
var textPos = new Coordinate2D(5, 3).ToMapPoint();
var tElement = PresentationElementFactory.Instance.CreateTextGraphicElement(page,
TextType.PointText, textPos, sym, textString, "telement", false, elemInfo);
//create a group element with elements created above
var elmList = new List<Element> { gElement, tElement };
GroupElement grp1 = PresentationElementFactory.Instance.CreateGroupElement(page, elmList, "My Group");
System.Object
ArcGIS.Desktop.Layouts.ElementInfo
