//Create a legend for an associated map frame.
//Note: Must be on QueuedTask.Run
//Build 2D envelope geometry
Coordinate2D leg_ll = new Coordinate2D(6, 2.5);
Coordinate2D leg_ur = new Coordinate2D(8, 4.5);
Envelope leg_env = EnvelopeBuilderEx.CreateEnvelope(leg_ll, leg_ur);
//Reference MF, create legend and add to layout
mapFrame = layout.FindElement("New Map Frame") as MapFrame;
if (mapFrame == null)
//TODO handle null map frame
return;
var legendInfo = new LegendInfo()
MapFrameName = mapFrame.Name
Legend legendElm = ElementFactory.Instance.CreateMapSurroundElement(
layout, leg_env, legendInfo, "New Legend") as Legend;
//Create a table frame.
Coordinate2D rec_ll = new Coordinate2D(1.0, 3.5);
Coordinate2D rec_ur = new Coordinate2D(7.5, 4.5);
Envelope rec_env = EnvelopeBuilderEx.CreateEnvelope(rec_ll, rec_ur);
//Reference map frame and layer
MapFrame mf = layout.FindElement("Map Frame") as MapFrame;
FeatureLayer lyr = mf.Map.FindLayers("GreatLakes").First() as FeatureLayer;
//Build fields list
var fields = new[] { "NAME", "Shape_Area", "Shape_Length" };
//Construct the table frame
var tableFrameInfo = new TableFrameInfo()
FieldNames = fields,
MapFrameName = mf.Name,
MapMemberUri = lyr.URI
var tabFrame = ElementFactory.Instance.CreateMapSurroundElement(
layout, rec_env, tableFrameInfo) as TableFrame;
//Build geometry
Coordinate2D ll = new Coordinate2D(6, 2.5);
Coordinate2D ur = new Coordinate2D(8, 4.5);
Envelope env = EnvelopeBuilderEx.CreateEnvelope(ll, ur);
var surroundInfo = new LegendInfo()
var legendElm = ElementFactory.Instance.CreateMapSurroundElement(
layout, env.Center, surroundInfo) as Legend;
legendElm.SetName("New Legend");
//Build geometry
Coordinate2D center = new Coordinate2D(7, 5.5);
//Reference a North Arrow in a style
StyleProjectItem stylePrjItm = Project.Current.GetItems<StyleProjectItem>()
.FirstOrDefault(item => item.Name == "ArcGIS 2D");
NorthArrowStyleItem naStyleItm = stylePrjItm.SearchNorthArrows(
"ArcGIS North 10")[0];
//Reference MF, create north arrow and add to layout
var mf = layout.FindElement("Map Frame") as MapFrame;
var narrow_info = new NorthArrowInfo()
NorthArrowStyleItem = naStyleItm
var arrowElm = (NorthArrow)ElementFactory.Instance.CreateMapSurroundElement(
layout, center.ToMapPoint(), narrow_info) as NorthArrow;
arrowElm.SetName("New North Arrow");
arrowElm.SetHeight(1.75);
arrowElm.SetX(7);
arrowElm.SetY(6);
//Build geometry
Coordinate2D ll = new Coordinate2D(1, 1);
Coordinate2D ur = new Coordinate2D(4, 4);
MapFrameName = "Map Frame",
MapMemberUri = "CIMPATH=USNationalParks/NationalParks.json"
var attribs = new List<CIMStringMap>();
for (int i = 1; i < 6; i++)
attribs.Add(new CIMStringMap
Key = $"Key {i}",
Value = $"Value {i}"
var elemInfo = new ElementInfo()
CustomProperties = attribs
var tableFrameElem = ElementFactory.Instance.CreateMapSurroundElement(
layout, env.Center, tableFrameInfo,
"New Table Frame", false, elemInfo) as TableFrame;
//Build geometry
Coordinate2D ll = new Coordinate2D(5.0, 6);
Coordinate2D ur = new Coordinate2D(6.0, 7);
Envelope sbEnv = EnvelopeBuilderEx.CreateEnvelope(ll, ur);
//Reference a Scale Bar in a style
ScaleBarStyleItem sbStyleItm = stylePrjItm.SearchScaleBars(
"Alternating Scale Bar 1")[0];
//ScaleBarStyleItem sbStyleItm = stylePrjItm.SearchScaleBars(
// "Double Alternating Scale Bar 1")[0];
// "Hollow Scale Bar 1")[0];
//Create Scale Bar
ScaleBarInfo sbInfo = new ScaleBarInfo()
MapFrameName = mapFrame.Name,
var sbElm = ElementFactory.Instance.CreateMapSurroundElement(
layout, sbEnv, sbInfo) as ScaleBar;
//Build geometry
Coordinate2D ll = new Coordinate2D(5.0, 8);
Coordinate2D ur = new Coordinate2D(6.0, 9);
"Scale Line 1")[0];
// "Stepped Scale Line")[0];
// "Scale Line 2")[0];
//Create Scale Bar
ScaleBarStyleItem = sbStyleItm
layout, sbEnv, sbInfo, "ScaleBar Line") as ScaleBar;
