ArcGIS.Desktop.Layouts Namespace / MapSurroundInfo Class / MapMemberUri Property
Example
    MapMemberUri Property (MapSurroundInfo)
    Gets and sets the associated map member URI
    Syntax
    Public Property MapMemberUri As String
    public string MapMemberUri {get; set;}
    Example
    Create Table Frame
      //Create a table frame.
      //Note: Must be on QueuedTask.Run
      //Build 2D envelope geometry
      Coordinate2D rec_ll = new Coordinate2D(1.0, 3.5);
      Coordinate2D rec_ur = new Coordinate2D(7.5, 4.5);
      Envelope rec_env = EnvelopeBuilderEx.CreateEnvelope(rec_ll, rec_ur);
      //Reference map frame and layer
      MapFrame mf = layout.FindElement("Map Frame") as MapFrame;
      FeatureLayer lyr = mf.Map.FindLayers("GreatLakes").First() as FeatureLayer;
      //Build fields list
      var fields = new[] { "NAME", "Shape_Area", "Shape_Length" };
      //Construct the table frame
      var tableFrameInfo = new TableFrameInfo()
        FieldNames = fields,
        MapFrameName = mf.Name,
        MapMemberUri = lyr.URI
      var tabFrame = ElementFactory.Instance.CreateMapSurroundElement(
        layout, rec_env, tableFrameInfo) as TableFrame;
    Create Table Frame 2
      //Build geometry
      Coordinate2D ll = new Coordinate2D(1, 1);
      Coordinate2D ur = new Coordinate2D(4, 4);
      Envelope env = EnvelopeBuilderEx.CreateEnvelope(ll, ur);
        MapFrameName = "Map Frame",
        MapMemberUri = "CIMPATH=USNationalParks/NationalParks.json"
      var attribs = new List<CIMStringMap>();
      for (int i = 1; i < 6; i++)
        attribs.Add(new CIMStringMap
          Key = $"Key {i}",
          Value = $"Value {i}"
      var elemInfo = new ElementInfo()
        CustomProperties = attribs
      var tableFrameElem = ElementFactory.Instance.CreateMapSurroundElement(
                                    layout, env.Center, tableFrameInfo,
                                    "New Table Frame", false, elemInfo) as TableFrame;
    Requirements
