ArcGIS.Desktop.Mapping Namespace / FeatureLayer Class / CanCreateRenderer Method
A renderer definition object.
    CanCreateRenderer Method (FeatureLayer)
    Determines whether a renderer can be created and is valid for the feature layer using the specified RendererDefinition. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public bool CanCreateRenderer(
       RendererDefinition rendererDefinition
    Public Function CanCreateRenderer( _
       ByVal rendererDefinition As RendererDefinition _
    ) As Boolean
    Parameters
    rendererDefinition
    Return Value
    A boolean indicates that a renderer can be created for the layer.
    Exceptions
    ExceptionDescription
    Remarks
    Certain renderers are only appropriate for certain layer types or for layers of a certain geometry type. For example a Dot Density Renderer can only be applied to a polygon layer, a Heat Map Renderer can only be applied to a point layer.
    Requirements
