ArcGIS.Desktop.Mapping Namespace / TrayButton Class / ConstructPopupContent Method
    Constructs a ContentControl that will be displayed as the Content within a popup window.
    Syntax
    protected virtual ContentControl ConstructPopupContent()
    Protected Overridable Function ConstructPopupContent() As ContentControl
    Return Value
    A ContentControl that will be displayed each time the popup is opened. if null is returned (the default) then the popup window will be blank.
    Remarks
    Only available if ButtonType is TrayButtonType.PopupToggleButton
    A new instance of the popup ContentControl will be constructed each time the popup is opened.
    Requirements
