ArcGIS.Desktop.Mapping Namespace / TrayButton Class / Dispose Method / Dispose(Boolean) Method
A value indicating, if true, that Dispose is being called from Dispose and if false, that Dispose is being called from the instance Finalizer
    Invoked when the enclosing View is closed and disposed.
    Syntax
    protected virtual void Dispose(
       bool isDisposing
    Protected Overloads Overridable Sub Dispose( _
       ByVal isDisposing As Boolean _
    Parameters
    isDisposing
    Remarks
    Override this to ensure proper disposal of instance resources - it will be invoked only once.
    If the parameter isDisposing is true, then an override should dispose all managed and unmanaged objects.
    Otherwise, if isDisposing is false, then an override should dispose unmanaged objects only - because it is being called as part of the instance Finalizer.
    Requirements
