| Exception | Description |
| ArcGIS.Core.Geometry.Exceptions.GeometryException | This feature's type of shape (i.e., geometry) is not supported. |
await QueuedTask.Run(() =>
using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file\\sdefile.sde"))))
using (FeatureClass schoolBoundaryFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.SchoolBoundary"))
// Using a spatial query filter to find all features which have a certain district name and lying within a given Polygon.
SpatialQueryFilter spatialQueryFilter = new SpatialQueryFilter
WhereClause = "DISTRCTNAME = 'Indian Prairie School District 204'",
FilterGeometry = new PolygonBuilderEx(new List<Coordinate2D>
new Coordinate2D(1021880, 1867396),
new Coordinate2D(1028223, 1870705),
new Coordinate2D(1031165, 1866844),
new Coordinate2D(1025373, 1860501),
new Coordinate2D(1021788, 1863810)
}).ToGeometry(),
SpatialRelationship = SpatialRelationship.Within
using (RowCursor indianPrairieCursor = schoolBoundaryFeatureClass.Search(spatialQueryFilter, false))
while (indianPrairieCursor.MoveNext())
using (Feature feature = (Feature)indianPrairieCursor.Current)
// Process the feature. For example...
Console.WriteLine(feature.GetObjectID());
using (FeatureClass enterpriseFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.FacilitySite"))
List<Coordinate2D> newCoordinates = new List<Coordinate2D>
new Coordinate2D(1021570, 1880583),
new Coordinate2D(1028730, 1880994),
new Coordinate2D(1029718, 1875644),
new Coordinate2D(1021405, 1875397)
SpatialQueryFilter spatialFilter = new SpatialQueryFilter
WhereClause = "FCODE = 'Park'",
FilterGeometry = new PolygonBuilderEx(newCoordinates).ToGeometry(),
SpatialRelationship = SpatialRelationship.Crosses
// For Selecting all matching entries.
using (Selection anotherSelection = enterpriseFeatureClass.Select(spatialFilter, SelectionType.ObjectID, SelectionOption.Normal))
// This can be used to get one record which matches the criteria. No assumptions can be made about which record satisfying the
// criteria is selected.
using (Selection onlyOneSelection = enterpriseFeatureClass.Select(spatialFilter, SelectionType.ObjectID, SelectionOption.OnlyOne))
// This can be used to obtain an empty selction which can be used as a container to combine results from different selections.
using (Selection emptySelection = enterpriseFeatureClass.Select(spatialFilter, SelectionType.ObjectID, SelectionOption.Empty))
// If you want to select all the records in a table.
using (Selection allRecordSelection = enterpriseFeatureClass.Select(null, SelectionType.ObjectID, SelectionOption.Normal))
Task FindSpatiallyRelatedFeaturesUsingDE9IMPredicateAsync(Geodatabase geodatabase, FeatureClass polygonFeatureClass, FeatureClass polylineFeatureClass) => QueuedTask.Run(() =>
using (RowCursor polygonRowCursor = polygonFeatureClass.Search(new QueryFilter()))
if (polygonRowCursor.MoveNext())
using (Feature polygonFeature = polygonRowCursor.Current as Feature)
// DE9IM predicate string to find overlapping features
string overlappingDE9IM = "1*T***T**";
SpatialQueryFilter spatialQueryFilter = new SpatialQueryFilter()
FilterGeometry = polygonFeature.GetShape(),
SpatialRelationship = SpatialRelationship.Relation,
SpatialRelationshipDescription = overlappingDE9IM
using (RowCursor overlappingPolyline = polylineFeatureClass.Search(spatialQueryFilter))
while (overlappingPolyline.MoveNext())
// Overlapping polylines on the polygon
var mapView = MapView.Active;
if (mapView == null)
return;
if (!featSceneLayer.HasAssociatedFeatureService)
return;//no search or select
//Select all features within the current map view
var sz = mapView.GetViewSize();
var map_pt1 = mapView.ClientToMap(new System.Windows.Point(0, sz.Height));
var map_pt2 = mapView.ClientToMap(new System.Windows.Point(sz.Width, 0));
//Convert to an envelope
var temp_env = EnvelopeBuilderEx.CreateEnvelope(map_pt1, map_pt2, mapView.Map.SpatialReference);
//Project if needed to the layer spatial ref
SpatialReference sr = null;
using (var fc = featSceneLayer.GetFeatureClass())
using (var fdef = fc.GetDefinition())
sr = fdef.GetSpatialReference();
var env = GeometryEngine.Instance.Project(temp_env, sr) as Envelope;
//Set up a query filter
var sf = new SpatialQueryFilter()
FilterGeometry = env,
SpatialRelationship = SpatialRelationship.Intersects,
SubFields = "*"
//Select against the feature service
var select = featSceneLayer.Select(sf);
if (select.GetCount() > 0)
//enumerate over the selected features
using (var rc = select.Search())
while (rc.MoveNext())
using (var feature = rc.Current as Feature)
oid = feature.GetObjectID();
//etc.
mapView.Map.ClearSelection();
