ArcGIS.Desktop.Mapping Namespace / IDisplayTable Interface / GetDisplayExpressions Method
An array of oids
    GetDisplayExpressions Method (IDisplayTable)
    Gets the display expressions of the given set of objects. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Function GetDisplayExpressions( _
       ByVal oids As IEnumerable(Of Long) _
    ) As List(Of String)
    List<string> GetDisplayExpressions(
       IEnumerable<long> oids
    Parameters
    oids
    An array of oids
    Return Value
    A correspondingly indexed array of display expressions for the given Oids.
    Exceptions
    ExceptionDescription
    Requirements
