ArcGIS.Core.Data Namespace / SpatialQueryFilter Class / SpatialRelationship Property
Example
    SpatialRelationship Property (SpatialQueryFilter)
    Gets and sets the SpatialRelationship to use for the spatial filter.
    Syntax
    public SpatialRelationship SpatialRelationship {get; set;}
    Public Property SpatialRelationship As SpatialRelationship
    Example
    Searching a FeatureClass using SpatialQueryFilter
      await QueuedTask.Run(() =>
        using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file\\sdefile.sde"))))
        using (FeatureClass schoolBoundaryFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.SchoolBoundary"))
          // Using a spatial query filter to find all features which have a certain district name and lying within a given Polygon.
          SpatialQueryFilter spatialQueryFilter = new SpatialQueryFilter
            WhereClause = "DISTRCTNAME = 'Indian Prairie School District 204'",
            FilterGeometry = new PolygonBuilderEx(new List<Coordinate2D>
              new Coordinate2D(1021880, 1867396),
              new Coordinate2D(1028223, 1870705),
              new Coordinate2D(1031165, 1866844),
              new Coordinate2D(1025373, 1860501),
              new Coordinate2D(1021788, 1863810)
            }).ToGeometry(),
            SpatialRelationship = SpatialRelationship.Within
          using (RowCursor indianPrairieCursor = schoolBoundaryFeatureClass.Search(spatialQueryFilter, false))
            while (indianPrairieCursor.MoveNext())
              using (Feature feature = (Feature)indianPrairieCursor.Current)
                // Process the feature. For example...
                Console.WriteLine(feature.GetObjectID());
    Selecting Features from a FeatureClass
        using (FeatureClass enterpriseFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.FacilitySite"))
          List<Coordinate2D> newCoordinates = new List<Coordinate2D>
            new Coordinate2D(1021570, 1880583),
            new Coordinate2D(1028730, 1880994),
            new Coordinate2D(1029718, 1875644),
            new Coordinate2D(1021405, 1875397)
          SpatialQueryFilter spatialFilter = new SpatialQueryFilter
            WhereClause = "FCODE = 'Park'",
            FilterGeometry = new PolygonBuilderEx(newCoordinates).ToGeometry(),
            SpatialRelationship = SpatialRelationship.Crosses
          // For Selecting all matching entries.
          using (Selection anotherSelection = enterpriseFeatureClass.Select(spatialFilter, SelectionType.ObjectID, SelectionOption.Normal))
          // This can be used to get one record which matches the criteria. No assumptions can be made about which record satisfying the
          // criteria is selected.
          using (Selection onlyOneSelection = enterpriseFeatureClass.Select(spatialFilter, SelectionType.ObjectID, SelectionOption.OnlyOne))
          // This can be used to obtain an empty selction which can be used as a container to combine results from different selections.
          using (Selection emptySelection = enterpriseFeatureClass.Select(spatialFilter, SelectionType.ObjectID, SelectionOption.Empty))
          // If you want to select all the records in a table.
          using (Selection allRecordSelection = enterpriseFeatureClass.Select(null, SelectionType.ObjectID, SelectionOption.Normal))
    Spatial query filter with DE9-IM spatial relationships
      Task FindSpatiallyRelatedFeaturesUsingDE9IMPredicateAsync(Geodatabase geodatabase, FeatureClass polygonFeatureClass, FeatureClass polylineFeatureClass) => QueuedTask.Run(() =>
        using (RowCursor polygonRowCursor = polygonFeatureClass.Search(new QueryFilter()))
          if (polygonRowCursor.MoveNext())
            using (Feature polygonFeature = polygonRowCursor.Current as Feature)
              // DE9IM predicate string to find overlapping features
              string overlappingDE9IM = "1*T***T**";
              SpatialQueryFilter spatialQueryFilter = new SpatialQueryFilter()
                FilterGeometry = polygonFeature.GetShape(),
                SpatialRelationship = SpatialRelationship.Relation,
                SpatialRelationshipDescription = overlappingDE9IM
              using (RowCursor overlappingPolyline = polylineFeatureClass.Search(spatialQueryFilter))
                while (overlappingPolyline.MoveNext())
                  // Overlapping polylines on the polygon
    Use Select or Search with a Spatial Query
      var mapView = MapView.Active;
      if (mapView == null)
        return;
        if (!featSceneLayer.HasAssociatedFeatureService)
          return;//no search or select
        //Select all features within the current map view
        var sz = mapView.GetViewSize();
        var map_pt1 = mapView.ClientToMap(new System.Windows.Point(0, sz.Height));
        var map_pt2 = mapView.ClientToMap(new System.Windows.Point(sz.Width, 0));
        //Convert to an envelope
        var temp_env = EnvelopeBuilderEx.CreateEnvelope(map_pt1, map_pt2, mapView.Map.SpatialReference);
        //Project if needed to the layer spatial ref
        SpatialReference sr = null;
        using (var fc = featSceneLayer.GetFeatureClass())
        using (var fdef = fc.GetDefinition())
          sr = fdef.GetSpatialReference();
        var env = GeometryEngine.Instance.Project(temp_env, sr) as Envelope;
        //Set up a query filter
        var sf = new SpatialQueryFilter()
          FilterGeometry = env,
          SpatialRelationship = SpatialRelationship.Intersects,
          SubFields = "*"
        //Select against the feature service
        var select = featSceneLayer.Select(sf);
        if (select.GetCount() > 0)
          //enumerate over the selected features
          using (var rc = select.Search())
            while (rc.MoveNext())
              using (var feature = rc.Current as Feature)
                oid = feature.GetObjectID();
                //etc.
        mapView.Map.ClearSelection();
    Requirements
