ArcGIS.Desktop.Mapping Namespace / IElement Interface / GetBounds Method
True to retrieve the rotated bounds
    GetBounds Method (IElement)
    Gets the bounding box for the element. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Function GetBounds( _
       Optional ByVal rotated As Boolean _
    ) As Envelope
    Envelope GetBounds(
       bool rotated
    Parameters
    rotated
    Return Value
    Exceptions
    ExceptionDescription
    This method must be called within the lambda passed to QueuedTask.Run.
    Remarks
    Bounds always reflect the element extent in a non-rotated orientation. If element rotation is non-zero, use graphicBounds = true to return the minimum bounding box enclosing the element in its rotated position
    Requirements
