ArcGIS.Desktop.Mapping Namespace / IElement Interface / GetLockedAspectRatio Method
    GetLockedAspectRatio Method (IElement)
    Gets the locked aspect ratio value of the element. If This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Function GetLockedAspectRatio() As Boolean
    bool GetLockedAspectRatio()
    Return Value
    Returns a Boolean
    Exceptions
    ExceptionDescription
    This method must be called within the lambda passed to QueuedTask.Run.
    Remarks
    Returns true if an element has maintain aspect ratio enabled.
    Requirements
