Sub SetLockedAspectRatio( _ ByVal lockedAspectRatio As Boolean _ )
void SetLockedAspectRatio( bool lockedAspectRatio )
Parameters
- lockedAspectRatio
- Double
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method must be called within the lambda passed to QueuedTask.Run. |
| System.InvalidOperationException | This element requires its mapview to be active |
true, this means if element width is set, then the element height will be automatically adjusted appropriately. The same is true if height were modified, then width would automatically be adjusted.Target Platforms: Windows 11 Home, Pro, Enterprise (64 bit)
