ArcGIS.Desktop.Mapping Namespace / IElement Interface / SetTOCPositionRelative Method
An existing element in the layout TOC.
Boolean
    SetTOCPositionRelative Method (IElement)
    Sets the position of an element either above or below a reference element. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Sub SetTOCPositionRelative( _
       ByVal targetElement As IElement, _
       ByVal isAbove As Boolean _
    void SetTOCPositionRelative(
       IElement targetElement,
       bool isAbove
    Parameters
    targetElement
    isAbove
    Boolean
    Exceptions
    ExceptionDescription
    This method must be called within the lambda passed to QueuedTask.Run.
    Remarks
    If set to true, the element is placed above the reference element. The reference element can either be at the root level of the layout TOC or an element in a group element. Elements can be easily moved into or out of groups.
    Requirements
