ArcGIS.Desktop.Mapping Namespace / IElement Interface / SetWidth Method
Double
    SetWidth Method (IElement)
    Sets the width of the element. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Sub SetWidth( _
       ByVal width As Double _
    void SetWidth(
       double width
    Parameters
    width
    Double
    Exceptions
    ExceptionDescription
    This method must be called within the lambda passed to QueuedTask.Run.
    This element requires its mapview to be active
    Remarks
    Placement for an element contained in graphics layer requires the mapview be active
    Requirements
