ArcGIS.Desktop.Mapping.Voxel Namespace / VoxelVariableProfile Class / Statistics Property
Example
    Statistics Property (VoxelVariableProfile)
    Gets the variable statistics.
    Syntax
    public VoxelVariableStatistics Statistics {get;}
    Public ReadOnly Property Statistics As VoxelVariableStatistics
    Example
    Access Stats and Color Range for a Stretch Renderer
      //Get the variable profile on which to access the data
      var variable = voxelLayer.SelectedVariableProfile;
      //or use ...voxelLayer.GetVariableProfiles()
      //Data range
      var min = variable.Statistics.MinimumValue;
      var max = variable.Statistics.MaximumValue;
      //Color range (Continuous only)
      double color_min, color_max;
      if (variable.DataType == VoxelVariableDataType.Continuous)
        var renderer = variable.Renderer as CIMVoxelStretchRenderer;
        color_min = renderer.ColorRangeMin;
        color_max = renderer.ColorRangeMax;
    Change Stretch Renderer Color Range
      //Typically, the default color range covers the most
      //commonly occurring voxel values. Usually, the data
      //range is much broader than the color range
      await QueuedTask.Run(() =>
        //Get the variable profile whose renderer will be changed
        //Check DataType
        if (variable.DataType != VoxelVariableDataType.Continuous)
          //must be continuous to have a Stretch Renderer...
        var color_min = renderer.ColorRangeMin;
        var color_max = renderer.ColorRangeMax;
        //increase range by 10% of the current difference
        var dif = (color_max - color_min) * 0.05;
        color_min -= dif;
        color_max += dif;
        //make sure we do not exceed data range
        if (color_min < variable.Statistics.MinimumValue)
          color_min = variable.Statistics.MinimumValue;
        if (color_max > variable.Statistics.MaximumValue)
          color_max = variable.Statistics.MaximumValue;
        //variable.Statistics.MinimumValue
        renderer.ColorRangeMin = color_min;
        renderer.ColorRangeMax = color_max;
        //apply changes
        variable.SetRenderer(renderer);
    Create Isosurface
        //Visualization must be surface
        if (voxelLayer.Visualization != VoxelVisualization.Surface)
          voxelLayer.SetVisualization(VoxelVisualization.Surface);
        //Get the variable profile on which to create the iso surface
        // o Visualization must be Surface
        // o Variable profile must be continuous
        // o Variable MaxNumberofIsoSurfaces must not have been reached...
        if (variable.CanCreateIsosurface)
          //Note: calling create if variable.CanCreateIsosurface == false
          //will trigger an InvalidOperationException
          //Specify a voxel value for the iso surface
          var mid = (max + min) / 2;
          //color range (i.e. values that are being rendered)
          //keep the surface within the current color range (or it
          //won't render)
          if (mid < color_min)
            mid = renderer.ColorRangeMin;
          else if (mid > color_max)
            mid = renderer.ColorRangeMax;
          //Create the iso surface
          var suffix = Math.Truncate(mid * 100) / 100;
          variable.CreateIsosurface(new IsosurfaceDefinition()
            Name = $"Surface {suffix}",
            Value = mid,
            IsVisible = true
    Requirements
