ArcGIS.Desktop.Mapping.Voxel Namespace / VoxelVolume Class / DeleteSection Method
The definition of the section to delete.
Example
    DeleteSection Method (VoxelVolume)
    Delete the specified section. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void DeleteSection(
       SectionDefinition sectionDef
    Public Sub DeleteSection( _
       ByVal sectionDef As SectionDefinition _
    Parameters
    sectionDef
    Exceptions
    ExceptionDescription
    This method or property must be called within the lambda passed to QueuedTask.Run
    Invalid section definition specified
    Section is null
    Section not found in the collection of sections
    Example
    Delete Sections
      await QueuedTask.Run(() =>
        //Use the SelectedVariableProfile to get the sections
        //via its associated volume
        var volume = voxelLayer.SelectedVariableProfile.Volume;
        foreach (var section in volume.GetSections())
          volume.DeleteSection(section);
        //optional...
        if (voxelLayer.Visualization != VoxelVisualization.Volume)
          voxelLayer.SetVisualization(VoxelVisualization.Volume);
    Requirements
