ArcGIS.Desktop.Mapping.Voxel Namespace / VoxelVolume Class / GetPositionRange Method
A point in voxel space
A normal unit vector
    Gets the range of positions in voxel coordinates. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    point
    normal
    Return Value
    Min and max positions in voxel coordinates.
    Exceptions
    ExceptionDescription
    This method or property must be called within the lambda passed to QueuedTask.Run
    Remarks
    The position range represents the minimum and maximum voxel coordinate values of a vector that runs through the given point in voxel space in the direction of the specified normal.
    Requirements
