ArcGIS.Desktop.Mapping.Voxel Namespace / VoxelVolume Class / GetSlices Method
Example
    GetSlices Method
    Gets the collection of slices
    Syntax
    public IList<SliceDefinition> GetSlices()
    Public Function GetSlices() As IList(Of SliceDefinition)
    Example
    Get the Collection of Slices
      await QueuedTask.Run(() =>
        //Use the SelectedVariableProfile to get the slices currently in the TOC
        //via its associated volume
        var volume = voxelLayer.SelectedVariableProfile.Volume;
        var slices = volume.GetSlices();
        //Do something... e.g. make them visible
        foreach (var slice in slices)
          slice.IsVisible = true;
          volume.UpdateSlice(slice);
        //expand the slice container and make sure container visibility is true
        voxelLayer.SetSliceContainerExpanded(true);
        voxelLayer.SetSliceContainerVisibility(true);
    Get a Slice
      var slice = volume.GetSlices().FirstOrDefault();
      var slice2 = volume.GetSlices().First(s => s.Id == my_slice_id);
    Change Tilt on a Slice
        //To stop the Voxel Exploration Dockpane activating use:
        voxelLayer.AutoShowExploreDockPane = false;
        //This is useful if u have your own dockpane currently activated...
        //Normally, it would be set in your dockpane
        if (voxelLayer.Visualization != VoxelVisualization.Volume)
          voxelLayer.SetVisualization(VoxelVisualization.Volume);
        var slice = volume.GetSlices().First(s => s.Name == "Change Tilt Slice");
        (double orientation, double tilt) = voxelLayer.GetOrientationAndTilt(slice.Normal);
        //Convert orientation and tilt to a normal
        slice.Normal = voxelLayer.GetNormal(orientation, 45.0);
        //reset if needed...Normally this might be when your dockpane
        //was de-activated (ie "closed")
        voxelLayer.AutoShowExploreDockPane = true;
    Delete Slice
        var last_slice = volume.GetSlices().LastOrDefault();
        if (last_slice != null)
          volume.DeleteSlice(last_slice);
        //Delete all slices
          volume.DeleteSlice(slice);
    Requirements
