ArcGIS.Core.Data Namespace / Subtype Class / GetName Method
Example
    GetName Method (Subtype)
    Gets the name value of the subtype. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public string GetName()
    Public Function GetName() As String
    Return Value
    The name value of the subtype.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    Example
    Get topology rules
      static void GetTopologyRules()
        using (Geodatabase geodatabase = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri(@"C:\TestData\GrandTeton.gdb"))))
        using (ArcGIS.Core.Data.Topology.Topology topology = geodatabase.OpenDataset<ArcGIS.Core.Data.Topology.Topology>("Backcountry_Topology"))
          using (TopologyDefinition topologyDefinition = topology.GetDefinition())
            IReadOnlyList<TopologyRule> rules = topologyDefinition.GetRules();
            Console.WriteLine($"There are {rules.Count} topology rules defined for the topology:");
            Console.WriteLine("ID \t Origin Class \t Origin Subtype \t Destination Class \t Destination Subtype \t Rule Type");
            foreach (TopologyRule rule in rules)
              Console.Write($"{rule.ID}");
              Console.Write(!String.IsNullOrEmpty(rule.OriginClass) ? $"\t{rule.OriginClass}" : "\t\"\"");
              Console.Write(rule.OriginSubtype != null ? $"\t{rule.OriginSubtype.GetName()}" : "\t\"\"");
              Console.Write(!String.IsNullOrEmpty(rule.DestinationClass) ? $"\t{rule.DestinationClass}" : "\t\"\"");
              Console.Write(rule.DestinationSubtype != null ? $"\t{rule.DestinationSubtype.GetName()}" : "\t\"\"");
              Console.Write($"\t{rule.RuleType}");
              Console.WriteLine();
    Requirements
